Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Thingworx was working fine till now and after a system update the tomcat is not starting and I have found an error in tomcat logs during tomcat service startup which is mentioned below.
Jan 17, 2024 4:45:22 AM org.apache.catalina.core.ApplicationContext log
INFO: No Spring WebApplicationInitializer types detected on classpath
Jan 17, 2024 4:45:29 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class [com.thingworx.system.ThingWorxBootstrapper]
I have also attached the application log and tomcat log along with this question.
Someone kindly help me to resolve this.
Thingworx version: 9.3.5-b1258
Java version: jdk-11.0.16.1
DB: PostgreSQL 15
Hi @BharathB
Properties getting loaded into memory that is causing a stack overflow error. kindly open a case as we'll need to evaluate the property_vtq table and clean up select properties, large infotables should not be stored as persisted properties.
Hi @BharathB
Thanks for sharing logs, kindly check the below location and let me know the theworx-platform-common-9.3.5-b1258.jar jar file is found in your instance.
file:/C:/Program%20Files%20(x86)/ThingWorxFoundation/tomcat/current/webapps/Thingworx/WEB-INF/lib/thingworx-platform-common-9.3.5-b1258.jar)
Hi @BharathB
Hi @BharathB
I have seen you have opened a case, thanks for this, we will provide support on it, kindly mark it as completed.
Hi @BharathB
We have already resolved this issue at the meeting in your opened case, kindly mark it as the solution.
Surya
