Proportional Chart
Feb 15, 2015
08:40 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Feb 15, 2015
08:40 PM
Proportional Chart
I'm trying to use the proportional chart, with dates on the x-axis and hours on the Y-axis. When I run it, the date is not showing below (says invalid date), and the hours data is showing all in one column. Any thoughts on why this would be happening?
Feb 16, 2015
12:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Feb 16, 2015
12:10 PM
Please make sure your mappings are correct. For the Invalid Number issue, check your datashape field definitions and make sure the datetime property has a base type of "datetime". In your widget mapping,
- XAxisLabelType set to "Date/Time"
For the data showing all in one column, again make sure to map properly your data and datafield.
- XAxisField has to have your datetime field selected.
Feb 18, 2015
01:52 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Feb 18, 2015
01:52 PM
It appears that you can't actually define the X-axis on a proportional chart. I had everything configured correctly. I ended up using the label chart instead and having to do a stacked series, which involved me having to pivot my table first.
Keri
