I'm trying to use the proportional chart, with dates on the x-axis and hours on the Y-axis. When I run it, the date is not showing below (says invalid date), and the hours data is showing all in one column. Any thoughts on why this would be happening?
It appears that you can't actually define the X-axis on a proportional chart. I had everything configured correctly. I ended up using the label chart instead and having to do a stacked series, which involved me having to pivot my table first.
Keri
