Query for Datatable using 'Like' constraint
ptc-6292144
3-Newcomer
I am looking to use the QueryDataTableEntries snippet however, I want the input from the user to be searched as a 'Like' string instead of an exact case match. For example, if the user searches 'TC' I want results containing 'TC1', 'TC2', 'TC3', etc. to be returned. Using the default snippet only returns results if they are entered exactly.
Thank you,
Mike
Take a look at section 03.14.06.01, Query Parameter for Query Services, of the wiki. It may help
Hi David,
Can you provide the link to access the wiki 03.14.06.01 section?
paic
(To:rkandasamy)
Since that Wiki no longer exists, go to the Help Documentation into the Java Doc and search for EQ or 'Query Parameter for Query Services' will work as well.
