I am running the following code in the Expression, but there is no output from the Expression. Does QueryNamedPropertyHistory work in Expression?
DataTable = Things["ThingName"].QueryNamedPropertyHistory({
propertyNames: {
"rows": [{
"name": "PropertyName"
"dataShape": {
"fieldDefinitions": {
"name": {
"name": "name",
"aspects": {},
"description": "",
"baseType": "STRING",
"ordinal": 1
"description": {
"name": "description",
"aspects": {},
"description": "",
"ordinal": 2
} /* INFOTABLE */ ,
maxItems: undefined /* NUMBER */ ,
query: undefined /* QUERY */ ,
maxDataItems: 500000 /* NUMBER */ ,
startDate: startDate /* DATETIME */ ,
endDate: endDate /* DATETIME */ ,
oldestFirst: true /* BOOLEAN */ ,
dataQuery: undefined /* QUERY */
if(DataTable.rows.length === 0)
Output = "No Data";
else{
Output = " ";
Shashi.
I don't think the QueryNamedPropertyHistory service will run in the expression function. You can get the length of infotable returned by QueryNamedPropertyHistory in a separate service and pass its output to the expression function. Refer this article explaining all the tasks that can be performed with Expression.
