Hi i'm SeonHo
When displaying a route using google map, is there a way to switch to a normal path if the distance between the point and the point is greater than a certain value [distance is too long]?
Or can not show the root for these values?
For example, if the GPS value in LA suddenly occurs in Corona, TWX connects LA and Corona in a straight line.
I want to know the function to replace this straight line with a normal path.
I would like to know the function that does not display the linear value of such a sudden case.
I had the same question before.
But I could not solve problem.
So I raise the same question again.
I'm sorry.
Thank you.
