hello~
I have found through the web browser that I can change the property value of THING with the REST API.
So how do I PUT or POST to the REST API in Eclipse?
I've referenced the community's POSTing via a REST call in Java, but it does not work.
Note: POST succeeded but not PUT. I did not make any code changes.
[context: com.thingworx.webservices.context.HttpExecutionContext@49f70e14] [message: JSON Content for said Not Not ValidProperties]
said is a property of restapi Thing.
We have encountered these issues while considering the rest method to transmit data from RS485 communication module.
How do I fix it?
Usually I test REST services using Postman | API Development Environment
If you want to use Eclipse one way will be to create simple REST client as mentioned in this post POSTing via a REST call in Java you said that doesn't work.
According to Javadoc HttpURLConnection (Java Platform SE 8 the HttpURLConnection.setRequestMethod() supports GET POST HEAD OPTIONS PUT DELETE TRACE so you will need to provide more details.
--Marek
in Additional
how to use GET method in Eclipse?
--Marek
import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.Response; public class Rest { /** * @throws IOException * @brief Get some information from the server */ void Get() throws IOException { OkHttpClient client = new OkHttpClient(); Request request = new Request.Builder() .url("https://academic.cloud.thingworx.com/Thingworx/Things/") .get() .addHeader("appKey", "XXXXXXXXXXXXXX") .addHeader("Content-Type", "application/json") .addHeader("Accept", "application/json") .addHeader("Cache-Control", "no-cache") .addHeader("Token", "XXXXXXXXXXXXXXXX") .build(); Response response = client.newCall(request).execute(); System.out.println(response.body().string()); }
for the xxxxxxxx insert the appkey you did create in the thingworx platform…..
import using maven pom.xml …..the following packages
<dependency> <groupId>com.squareup.okio</groupId> <artifactId>okio</artifactId> <version>2.0.0-RC1</version> </dependency> <dependency> <groupId>com.squareup.okhttp3</groupId> <artifactId>okhttp</artifactId> <version>3.11.0</version> </dependency> <dependency> <groupId>org.jetbrains.kotlin</groupId> <artifactId>kotlin-stdlib</artifactId> <version>1.2.61</version> </dependency> <dependency> <groupId>org.jetbrains.kotlin</groupId> <artifactId>kotlin-stdlib-common</artifactId> <version>1.2.61</version> </dependency>
enjoy…..the example is using the rest var get….the same can be accomplished with put...note that other inputs are required therefore….
