Reading xml from WeatherUnderground
gsee
I want to replace an existing weather service (from yahoo) with a WeatherUndergroup API.
I haven't been able to get my javascript code to actually read any of the current observation data, it just returns an empty result.
var API = me.WeatherUndergroundAPI;
var features = 'forecast';
var queryLocation = '30009';
var format = 'xml';
var url = 'http://api.wunderground.com/api/' + API + '/' + features + '/'  + '/q/' + queryLocation + '.' + format
var params = {
    url: url,
    timeout : 60
var xmlPage = Resources["ContentLoaderFunctions"].LoadXML(params);
var params = {
    infoTableName : "InfoTable",
    dataShapeName : "WeatherForecast"
me.WeatherHumidity = xmlPage.curren t_observation.relative_humidity;
result = xmlPage.current_observation.relative_humidity;
I'm trying to read from this xml:
<response>
<version>0.1</version>
<termsofService>
http://www.wunderground.com/weather/api/d/terms.html
</termsofService>
<features>
<feature>forecast</feature>
<feature>geolookup</feature>
<feature>conditions</feature>
</features>
<location>...</location>
<current_observation>
<estimated></estimated>
<station_id>KGAALPHA22</station_id>
<observation_time>Last Updated on May 4, 12:39 PM EDT</observation_time>
<observation_time_rfc822>Wed, 04 May 2016 12:39:43 -0400</observation_time_rfc822>
<observation_epoch>1462379983</observation_epoch>
<local_time_rfc822>Wed, 04 May 2016 12:39:55 -0400</local_time_rfc822>
<local_epoch>1462379995</local_epoch>
<local_tz_short>EDT</local_tz_short>
<local_tz_long>America/New_York</local_tz_long>
<local_tz_offset>-0400</local_tz_offset>
<weather>Mostly Cloudy</weather>
<temperature_string>65.7 F (18.7 C)</temperature_string>
<temp_f>65.7</temp_f>
<temp_c>18.7</temp_c>
<relative_humidity>57%</relative_humidity>
<wind_string>From the West at 4.2 MPH Gusting to 6.8 MPH</wind_string>
<wind_dir>West</wind_dir>
<wind_degrees>270</wind_degrees>
<wind_mph>4.2</wind_mph>
<wind_gust_mph>6.8</wind_gust_mph>
<wind_kph>6.8</wind_kph>
<wind_gust_kph>10.9</wind_gust_kph>
<pressure_mb>1009</pressure_mb>
<pressure_in>29.80</pressure_in>
<pressure_trend>0</pressure_trend>
<dewpoint_string>50 F (10 C)</dewpoint_string>
<dewpoint_f>50</dewpoint_f>
<dewpoint_c>10</dewpoint_c>
<heat_index_string>NA</heat_index_string>
<heat_index_f>NA</heat_index_f>
<heat_index_c>NA</heat_index_c>
<windchill_string>NA</windchill_string>
<windchill_f>NA</windchill_f>
<windchill_c>NA</windchill_c>
<feelslike_string>65.7 F (18.7 C)</feelslike_string>
<feelslike_f>65.7</feelslike_f>
<feelslike_c>18.7</feelslike_c>
<visibility_mi>10.0</visibility_mi>
<visibility_km>16.1</visibility_km>
<solarradiation/>
<UV>8</UV>
<precip_1hr_string>0.00 in ( 0 mm)</precip_1hr_string>
<precip_1hr_in>0.00</precip_1hr_in>
<precip_1hr_metric>0</precip_1hr_metric>
<precip_today_string>in ( mm)</precip_today_string>
<precip_today_in/>
<precip_today_metric/>
<icon>mostlycloudy</icon>
<icon_url>http://icons.wxug.com/i/c/k/mostlycloudy.gif</icon_url>
<forecast_url>http://www.wunderground.com/US/GA/Alpharetta.html</forecast_url>
</current_observation>
<forecast>...</forecast>
</response>
ttielebein
(To:gsee)
Hello, when I try to run this query within my web browser, I receive an error message. Are you sure this XML is returning properly to begin with?
URL: http://api.wunderground.com/api/<MY_KEY>/features/q/30009.xml
Error:
<error>
<type>unknownfeature</type>
</error>
That said, when I use a URL which DOES work for me in the browser in my JS, I do parse the XML correctly. Here is my script:
var params = {
    url: "http://api.wunderground.com/api/ee5785ebc5a63ea1/conditions/q/42.7,31.xml",
    timeout : 60
var result = xmlPage.current_observation.relative_humidity;
Let me know if this helps at all!
Tori
ttielebein
(To:gsee)
Error:
<error>
</error>
var params = {
    timeout : 60
Tori
gsee
(To:ttielebein)
Hi Tori,
Thanks, this helps. However, it's reading everything in as a string, even when I want to assign a numerical value to a property formatted as a number. For numbers, I've been casting them as Number(result), which is working fine. I can't get the dates to import correctly. Any recommendations there?
ttielebein
(To:gsee)
Hello again,
Great to be of assistance. Have you seen this documentation on implementing dates in ThingWorx? https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS231457
It is in the ThingWorx KCS database. Have you tried this already?
Thanks!
Tori
gsee
(To:ttielebein)
Hi Tori,
I missed this response, but thanks for the help!
I can access the page but not the document, unfortunately. I found as long as I parsed the data to a new variable, and then assigned the value to the parameter, it works. I'm not as familiar with javascript, so I'm not sure why the limitation, but I'm glad to be getting output at least. Hopefully there's garbage collection on the new variables I had to create once this scales up to more users.
What I ended up using looks like this:
var d = new Date(Date.parse("" + xmlDoc.current_observation.observation_time_rfc822));
me.newDate = d;
