Recover deleted data backup of data tables
rkandasamy
7-Bedrock
Hi Team,
By default, whether thingworx data tables are taken backup on daily basis. we have accidentally deleted some of the data tables.
If i could access last day data tables data , that would be helpful. Anybody has any idea?
Thanks in advance.
supandey
(To:rkandasamy)
Hi Rdhakrishnan, just so it's clear which database are you using as persistence provider? and is the instance hosted by CS or you have it locally running within your organization?
Rdhakrishnan Kandasamy​, As per my knowledge; the automatic database backup is done for Neo4j and H2. But not for Postgresql.
supandey
(To:ankigupta)
Ankit Gupta​ yeah I think that's correct. I think important setting to check, for PostgreSQL as Persistence Provider, here would be whether or not Rdhakrishnan Kandasamy​ has enabled the EnableBackup = true in platform-settings.json. If it's not then likely you don't have any backup whatsoever.
