A third part product send a rest rest call to Thingworx with the following formatting: "equipment/instance/{id}/state"
I need a solution (inside or outside tomcat) to transform the Rest call to something that Thingworx will accept, e.g. /Things/MyThingName/Services/getState?id={id}"
Is there an easy way to do this?
Thanks!
Alright thanks!
I added a reverse proxy (Nginx) in my infrastucture to handle this. I configured a 'rewrite' and I tested it using curl. It seems to be working well also using the basic Auth / -u in curl.
The service that you provide to ingest this rest call should be able to take the content and parse that.
Not exactly sure if you are saying that the third party can only send information as a specific 'URL' only without content.
The 3Part service can only send Rest Call of type "equipment/instance/{id}/state".
But Thingworx doesn't have any Thing named {id}, the id should be pass as a parameter, this is my issue.
That unfortunately is a very limited ability. Are you sure that is the only capability this device has? What device is this?
Also this is a GET? How would you include authentication (appkey)?
We are talking about a robot. The provider do not want to recompile the robot system so we need to implement a solution on our side. The authentication used is Basic Auth.
With those limitations, you may need to put something in between as a translation layer.
Alright thanks!
