we want to store some data for long term where the dataset maybe become huge and has frequent updates. The community recommends not to use DataTables for this usecase.
So I installed the Relational Database Extension and was quickly able to establish the connection and create the required tables. But now I run in some trouble as the datatable has a lot of columns and we transport the data in infotables around, I would like these infotables or JSONS as Parameters for the SQL-Query/Command.
How can I access these kind of parameters?
This example fails with an exception:
Unable to Invoke Service TestInsert_2 on SQL.ProductionTimeSegment : Execute Update failed: com.microsoft.sqlserver.jdbc.SQLServerException: Unclosed quotation mark after the character string '[JSON.Value]);'.
Additional Question: How can I handle secure dynamic SQL, e.g. create an Table machting a given DataShape?
Regarding your additional question, here's what we did in a similar scenario (dataShapeName is input parameter):
var formatType = function(baseType, dataShape) {
switch(baseType) {
case 'STRING': return 'varchar(255)';
case 'INTEGER': return 'int';
default: return '???';
var out = '';
var shape = DataShapes[dataShapeName];
if (shape.description) out += '-- ' + shape.description + '\n';
out += 'CREATE TABLE ' + dataShapeName + ' (\n';
var fields = shape.GetFieldDefinitions().rows;
for (var i = 0; i < fields.length; ++i) {
var field = fields[i];
out += '\t' + field.name + ' ' + formatType(field.baseType, field.dataShape);
if (i < fields.length - 1) out += ',';
if (field.description) out += ' -- ' + field.description;
out += '\n';
out += ');\n';
Things["SystemRepository"].SaveText({
path: '/' + dataShapeName + '.sql',
content: out
/ Constantine
Hi Constantin,
thanks for the code. Very helpfull.
Greetings
Andreas
