we want to store some data for long term where the dataset maybe become huge and has frequent updates. The community recommends not to use DataTables for this usecase.
So I installed the Relational Database Extension and was quickly able to establish the connection and create the required tables. But now I run in some trouble as the datatable has a lot of columns and we transport the data in infotables around, I would like these infotables or JSONS as Parameters for the SQL-Query/Command.
How can I access these kind of parameters?
This example fails with an exception:
Unable to Invoke Service TestInsert_2 on SQL.ProductionTimeSegment : Execute Update failed: com.microsoft.sqlserver.jdbc.SQLServerException: Unclosed quotation mark after the character string '[JSON.Value]);'.
Additional Question: How can I handle secure dynamic SQL, e.g. create an Table machting a given DataShape?
Regarding your additional question, here's what we did in a similar scenario (dataShapeName is input parameter):
var formatType = function(baseType, dataShape) { switch(baseType) { case 'STRING': return 'varchar(255)'; case 'INTEGER': return 'int'; default: return '???'; } }; var out = ''; var shape = DataShapes[dataShapeName]; if (shape.description) out += '-- ' + shape.description + '\n'; out += 'CREATE TABLE ' + dataShapeName + ' (\n'; var fields = shape.GetFieldDefinitions().rows; for (var i = 0; i < fields.length; ++i) { var field = fields[i]; out += '\t' + field.name + ' ' + formatType(field.baseType, field.dataShape); if (i < fields.length - 1) out += ','; if (field.description) out += ' -- ' + field.description; out += '\n'; } out += ');\n'; Things["SystemRepository"].SaveText({ path: '/' + dataShapeName + '.sql', content: out });
/ Constantine
Hi Constantin,
thanks for the code. Very helpfull.
Greetings
Andreas
