I created a connection between Kepserver and Thingworx with IndustrialConnectivityThing. The connection is successful. I now created a new thing with remotething template. I'm not sure where I have to set the value IndustrialConnectivityThing value in the new thing. I'm using TWX 8.3. Have done this in the earlier versions though
Data shape was not appropriately set. Hence the issue. This works fine now
