Replicating Bound KepServer Data to 2nd Instance of Thingworx
bmillice
We have two identical Thingworx instances, Dev and Prod.  We also have one single Kepserver, running on a Dell MicroPC, that we use to connect to Prod and bind the data to our Prod Thingworx.
I know that we cannot bind the same kepserver to a 2nd instance of Thingworx, so just curious as to what our options are to get the same data into our Dev instance?  (if possible)
I'm guessing that our only option is to run a service on dev to bind all the properties to the remote prod instance, but if that is the case, is there an easy way to then reconfigure the prod instance during the release process to bind to the kepserver?
I hope this isn't too confusing, any help is much appreciated!
PaiChung
22-Sapphire I
(To:bmillice)
Take a look into using the OPC aggregator to split an extra data stream.
