Reset thing property value to default value
SB_9732186
Hi all,
I want to reset all the properties of a thing to respective default values, how can this be done?
Sujith
(cannot edit last post for some reason)
Or just GetMetadata or via GetPropertyValues (also has default value)
12 REPLIES 12
PaiChung
22-Sapphire I
(To:SB_9732186)
With a service, you would have to pull the Property definitions and then find the 'default value' aspect.
Then assign that to the property value
I imagine you don't want to delete and recreate the Thing(s)
HD_10225728
6-Contributor
(To:PaiChung)
how can one set a property of type "number" back to nothing (so that "set value" will be displayed)? I tried setting it to null and undefined but that didn't work. The workaround was to set it to 0, but that is not optimal for what I'm trying to achieve
Thank you!
PaiChung
22-Sapphire I
(To:HD_10225728)
unfortunately if setting to null or undefined doesn't work, then I don't know either.
Hi @PaiChung ,
How do I fetch the Property Definitions with Default value aspect, because the service GetPropertyDefinitions gives me only these fields:
TWX 9.2
Sujith
PaiChung
22-Sapphire I
(To:SB_9732186)
Follow up with specific getpropertydefinition should give you more.
Hi @PaiChung ,
GetPropertyDefinition gives the same fields as well,
Sujith
PaiChung
22-Sapphire I
(To:SB_9732186)
Maybe you cut off some of the columns, isn't there an 'aspects' column? That would hold the information in regards to default value I believe.
Hi @PaiChung ,
There are no columns to cut off, only these many columns are available.
Sujith
PaiChung
22-Sapphire I
(To:SB_9732186)
I just went back to check and indeed ... it seems a whole lot of information is no longer supplied by GetPropertyDefinition
Not too sure what service to use anymore, I apologize.
@SB_9732186 service GetMetadataAsJSON will also return the default value - if a default value was specified in the property definition.
But I also have no idea on how to reset the property to "nothing".
Anyone else has a solution for this?
Or do I have to raise a case?
Sujith
