Jul 14, 2022 11:12 AM UTC
Reset thing property value to default value
Hi all,
I want to reset all the properties of a thing to respective default values, how can this be done?
Sujith
nmutterAnswer
Sep 3, 2022 10:34 AM UTC
(cannot edit last post for some reason)
Or just GetMetadata or via GetPropertyValues (also has default value)
22-Sapphire I
Jul 14, 2022 3:41 PM UTC
With a service, you would have to pull the Property definitions and then find the 'default value' aspect.
Then assign that to the property value
I imagine you don't want to delete and recreate the Thing(s)
Jul 15, 2022 6:46 AM UTC
how can one set a property of type "number" back to nothing (so that "set value" will be displayed)? I tried setting it to null and undefined but that didn't work. The workaround was to set it to 0, but that is not optimal for what I'm trying to achieve
Thank you!
22-Sapphire I
Jul 15, 2022 6:05 PM UTC
unfortunately if setting to null or undefined doesn't work, then I don't know either.
Aug 22, 2022 10:17 AM UTC
Anyone else has a solution for this?
Or do I have to raise a case?
Sujith
