Responsive Mashup Performance Testing
pshashipreetham
I have a Responsive Mashup with lots of Containers and Responsive widgets. I feel like it is slower compared to the static mashup.
Are there any articles(I didn't get anything from the Knowledge base) or tips for testing the Responsive mashup performance?
Shashi Preetham
4 REPLIES 4
It is possible that it could appear slower since the browser is trying to calculate dimensions based on data it needs to display and doesn't know this until it is retrieved.
How many services are you calling on the mashup and are the parallel or sequential.  The amount of services called on load can also affect your load times.
Travis
Hi @TravisPickett ,
The exact amount of services is present in Static Mashup. It loads within 6 secs, whereas Responsive mashup loads in 40secs. I have raised a support ticket with PTC and investigating it.
Shashi Preetham
Hi @pshashipreetham.
I saw that the case was closed without a solution.  Did you find a solution yourself?  If so, could you please share it with the community?
--Sharon
Hi @slangley ,
Thanks for following up. I will share the results on the weekend. I will document and share it.
Shashi Preetham
