Right click on menu to open new window
ehalvordsson
According to this article
https://www.ptc.com/en/support/article?n=CS242815
it should be possible to right click on a menu item in order to open a new window on click. However, the link created by the menu is invalid (testing in Thingworx 8.3). Is this feature disabled / a bug or is anyone aware of a way to acheive this?
This is what I want to acheive:
Standard - user clicks and the link is replacing the contained mashup.
Right click and open in new tab - the target mashup is opened in a new window.
Many thanks
Erik
posipova
20-Turquoise
(To:posipova)
EDIT: right click into a new tab resulting into a 404 is working per design. I corrected the article to reflect this.
5 REPLIES 5
I've just tested this in 8.3 and it does appear to not work. I will file a defect and report the jira number here soon.
posipova
20-Turquoise
(To:posipova)
Thank you for the reply.
We would expect that if you right click and use "open in new tab", then the target window should open in a new tab. Same with open in new window. Is that possible?
You can can configure your menu to open items either in a new tab or replacing the current page with the left click.
Thank you - I understand the current behavior of the widget but it is not what I  expect for a web page menu. I think you should review the menu concept for next release - redirecting to 404 on right click and is not what users would expect ...
