Run service Mashup by event button click in master.
NBHD207
Hi all,
I am using a master as follows:
The left sidebar contains widgets to enter values for filters and buttons. and "contained mashups" are mashups containing the grid whose data is queried from the database. I want to use the left bar to filter content for grids in mashups. But I don't know how to run the service in mashup when I click the button in master.
Is this possible or not?
Thanks and Best Regards.
1 ACCEPTED SOLUTION
NBHD207
(To:raluca_edu)
Thank you for your reply.
I have found a solution. I used the event refesh for the button in masters and used refreshRequested event to run service in Mashup
2 REPLIES 2
From my point of view it is possible if you are using mashup parameters and you pass them to the contained mashup.
Hope it helps,
Raluca Edu
NBHD207
(To:raluca_edu)
