Running EMS - Not Starting
vranganathan
I configured the config.json as follows
    "ws_servers":    [{
            "host":    "ec2-52-11-105-39.us-west-2.compute.amazonaws.com",
            "port":    80
    "appKey":    "3e871ea6-6f67-42ce-a6f0-4b2d041006f2",
"logger":    {
    "level":"DEBUG"
// Connection parameters
"ws_connection":    {
    "encryption":    "none", // Defaults to ssl
    "verbose":    true
// Certificate settings
// NOTE: Only certificates signed with the MD5 or SHA1 hash functions will be accepted
"certificates": {
    "validate": false, // Boolean. Set to false to turn off certificate validation. Default = true.
    "verbose": true
Then running as follows (nothing happens). Second time when I run it doesn't even display "Starting up..."
D:\apps\MicroServer>D:\apps\MicroServer\wsems.exe -cfg D:\apps\MicroServer\etc\config.json
[INFO ] 2015-07-09 22:57:20,792 D:\apps\MicroServer\wsems.exe: Using config file: D:\apps\MicroServer\etc\config.json
[FORCE] 2015-07-09 22:57:20,792 D:\apps\MicroServer\wsems.exe: Starting up ....
[INFO ] 2015-07-09 23:00:04,984 D:\apps\MicroServer\wsems.exe: Using config file: D:\apps\MicroServer\etc\config.json
Not sure what is wrong? I tried with -loglevel TRACE but no additional output. Any help in debugging this will help.
Thanks and Regards
2 REPLIES 2
The issue was the comments embedded in the file. System did not like those comments. Removing them solved my problem. I hope it is documented somewhere.
Varathan
paic
(To:vranganathan)
Correct, the config.json file has to be pure JSON which doesn't support comments.
