SAP Integration "Your route exchange has failed. Resource Error"
SaranKarthick
Hi Developers,
I'm trying this SAP Hands On Tutorial on Thingworx 8.0.1-b39. I have a SAP Gateway - Demo System (ES5) and my account have access to "https://sapes5.sapdevcenter.com/sap/opu/odata/IWBEP/GWSAMPLE_BASIC/". I have the integration runtime properly configured and running.
In Step 3 the following are the parameters i have given (the username and password are properly given not as shown below):
    • Generic Connector Connection Settings
      • Authentication Type = fixed
    • HTTP Connector Connection Settings
      • Username = <SAP Gateway user>
      • Password = < SAP Gateway pwd>
      • Base URL : https://sapes5.sapdevcenter.com/sap
      • Relative URL : /opu/odata/IWBEP/GWSAMPLE_BASIC/
      • Connection URL : /opu/odata/IWBEP/GWSAMPLE_BASIC/$metadata
The following are the errors i observed :
  • ValidateConnection
    Status Message ConnectorTemplate
    Failed
    Check logs for more details SAPODataConnector
  • GetEndpointList
    [context: com.thingworx.webservices.context.HttpExecutionContext@52e3b401][message: Unable to Invoke Service GetProductSet on ptc-SAP-OData-connector : Your route exchange has failed.  Resource Error [Connect to sapes5.sapdevcenter.com:443 [sapes5.sapdevcenter.com/155.56.38.41] failed: Connection timed out: connect]]
I'm suspecting the error is with this port sapes5.sapdevcenter.com/155.56.38.41 because i tested this URL ("https://sapes5.sapdevcenter.com/155.56.38.41") in the browser and it returned "HTTP 404 - Not found" page.
Could you please point out where i might be going wrong.
Saran
Hi developers,
I have found the root cause for this issue. It seems our internal network was blocking the port since i'm trying out with a external SAP system.
I connected to an external network and tried the same and got positive connection for the OData connector.
Saran
Hi developers,
Saran
Hi, Saran.
Thanks for letting us know what the solution was. Always worth it to check network configuration when there are communications issues.
If you're comfortable with this, please go ahead and mark your solution post as accepted, so others searching in the future with a similar problem can find it.
Thank you,
-- Craig A.
