SQL Query with WHERE and IN clause
Sathishkumar_C
How to implement SQL query in thingworx as follows,
Query:
SELECT * FROM Customers
WHERE Country NOT IN ('Germany''France''UK');
In thingworx, how to pass country names as input parameter.
Hi @Sathishkumar_C.
Take a look at this post to see if it helps.
--Sharon
14 REPLIES 14
No. Im going to use this query in "Database Thing" as "SQL Query". So, I want pass comma separated values to this query. How can i do with Thinworx SQL query services?
Mukul
(To:Sathishkumar_C)
you can try like this:
select * from user_model where name not in ([[name1]],[[name2]])
Where name1 and name2 are your service inputs.
Thanks Mukul for the support.
My case is inputs are dynamic. Based on multiple selection in drop-down, I want query using IN.
Mukul
(To:Sathishkumar_C)
You can try this approach, take all the selection as an infotable, push each value of that infotable column(country) into an array and make the array output something like ('Germany','France'); pass this String array as an input to SQL query service wherein put input like - select * from customers where country not in <<input>>;
Thanks for the support.
It seems, not working for me.
SQL query: testSQL
input (string)
select * from table where countrycode in input;
JavaScript Service:
var input = [530, 531];
let result = me.Test({
input: input /* STRING */
I am getting following error message.
Message :: Execute Update failed: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near ']'. - See Script Error Log for more details.
Let me know anything i missed here.
Mukul
(To:Sathishkumar_C)
change your query syntax like this:
select * from table where countrycode in <<input>>;
Change your input like this:
var input = ('530','531')
I tried the same.
Input basetype is String.
input = ('530','531');
Getting following error:
Execute Query failed: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near '@P0'.
Mukul
(To:Sathishkumar_C)
I think SQL server is not accepting it, I have postgres in my use case and it works fine like below. Let me test this with mssql, will get back to you.
Hi @Sathishkumar_C.
--Sharon
Thanks for you support. Let me test in my environment and confirm.
slangley
23-Emerald II
(To:slangley)
Hi @Sathishkumar_C.
Were you able to complete your testing?  What were the results?
--Sharon
Its working with only one value.
Not working with multiple comma separated values.
Hi Satish
try putting the input like  (<<filter>>) and not like([[filter]]) this is mentioned in the link provided by Sharon.
