Sample UI
asaito1
Sample UI
Hi All,
I am looking for good examples of what thingworx composer can do.
Where should I find some sample of UI?
Thanks!
Anselmo.
When I saw some examples of great web applications built using Composer I found myself asking the wrong questions - "What widgets did you use to build that?" Asking this question is like admiring a great photograph and asking what camera they used. Composer does not put many constraints on a website designer, the magic is in the design, not the tools.
We have a guide that breaks down how this professional web application was created in Composer with just 8 common widgets:
https://developer.thingworx.com/resources/guides/mashup-widget-breakdown
Mashup_start
dupatel
(To:asaito1)
@asaito1There are different way of building rich UI using built or custom widgets based on use case & requirements. Please see some samples as attached.
