Hi Guys,
I'm a beginner with ThingWorx, and have an application where an operator scans in a serial number of a device in need of service, and that number populates a serial number field on a current mashup which then follows the repair ticket through it's process.
Any ideas on how I should start this development? At the moment there is a drop down picker which populates a required service. Each service has it's own serial number code which automatically fills in that field and cannot be edited. I would like the have the user select a " repair " option which will then allow them to scan in a serial number which will populate the serial number field.
OOTB Navigate connects to a data management system like Windchill. The ability to collect raw data from sensors is found in ThingWorx, independent of Navigate. I’ll get this question moved to the ThingWorx board.
