Search Thing by identifier
seanccc
Everything can be searched by its identifier. I used to think that this field is indexed. But recently noticed that this field does not have any index in the table thing_model. Is this correct ?
Sean
yhan
(To:seanccc)
Hi @seanccc,
After checking twx postgresql database instance, the thing_model table has two below indexes, I think the identifier column value of the thing_model table can be the same in multiple rows and also can be null, so twx doesn't create an index for it OOTB.
  •  CREATE UNIQUE INDEX thing_model_pkey ON twx_schema.thing_model USING btree (entity_id)
  • CREATE UNIQUE INDEX thing_model_name_ukey ON twx_schema.thing_model USING btree (name)
/Yoyo
yhan
(To:seanccc)
Hi @seanccc,
/Yoyo
slangley
(To:seanccc)
Hi @seanccc.
If you are satisfied with the response you received, please mark the previous post as the Accepted Solution for the benefit of others with the same question.
--Sharon
