Dears,
I used change advanced to display something, and I can use grid config to change String type font color, but I used same way to hyperlink type, it not work, how should i do to change the hyperlink type font color, thank you!
Try custom css on the "<a> tag" inside the advanced grid widget class
Toolika Dixit
Toolika Dixit
