Search dropdownlist
rk-31
1-Newbie
Search dropdownlist
I am looking for a solution for Combobox where we can select and search also. Right now I am using List(view: dropsownlist). But it doesn't have facility to search.
Is there any solution for this ?
Aanjan RaviPai Chung
Raju
5 REPLIES 5
PaiChung
22-Sapphire I
(To:rk-31)
There is an extension in the Marketplace that might work for you called autocomplete
http://marketplace.thingworx.com/Items/autocomplete
Hi pai chung,
It seems that autocomplete cannot be used in Thingworx 7.4. So is there any alternative solution to this requirement?
Thanks!
Xiao Ying
PaiChung
22-Sapphire I
(To:xcheung)
That is strange ... because I'm using it on a project that is using 7.4.
Is the extension not installing for you?
Hi Pai Chung,
After I imported the Autocomplete widget extension from the marketplace in Thingworx 7.4 and placed it in the mashup, I cannot see anything when view the mashup. Even the label of the autocomplete cannot be seen in the mashup, don't know the reason.
P1: test of autocomplete
P2: view mashup (Nothing can be seen)
I found another person have the same problem, maybe we did similar mistakes?
Re: Autocomplete Widget not shown on Mashup in Thingworx 7.4
PaiChung
22-Sapphire I
(To:xcheung)
Oh that is very strange ... not sure what might be the reason, can you try a crtl+F5 on the mashup?
if that doesn't work maybe emptying of browser cache and a tomcat restart
