Select a row from collection widget using check box
MM_9023322
Hi all,
How to select a row from the collection widget using the check box?
Thank You.
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322.
Check out this community post to see if it will help.
--Sharon
3 REPLIES 3
MM_9023322
(To:VladimirN)
@VladimirN,
Thank you for your response, I have already tested using the grid widget and it's working as well. But  I want to use the Collection widget, not the grid widget.
Thank you!
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322.
--Sharon
