Hi all,
How to select a row from the collection widget using the check box?
Thank You.
Have a look at the solution here: https://community.ptc.com/t5/ThingWorx-Developers/I-want-to-create-a-Checkbox-to-select-a-row-in-a-grid-Is-it/td-p/507641
Thank you for your response, I have already tested using the grid widget and it's working as well. But I want to use the Collection widget, not the grid widget.
Thank you!
