The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I am currently displaying 8 variables in a time chart. I get the values from a database query service.
However, I would like to setup a list (or a checkbox list) where I can select the database columns to show in the chart (one or multiple at the same time).
Do you have any hint for this?
Kind regards,
Marco
Hi, I eventually solved that using checkboxes to change dinamically the data query binded to the charts.
Kind regards.
Hi @darcudarcu.
There is a Custom Chart Widgets v3.0.3 available through the Marketplace that should provide the functionality you need. The legend is interactive and allows you to hide/show the various series bound to the widget.
However, we are experiencing some issues with the Marketplace, so I am attaching it here.
--Sharon
Kind regards.
Hi @darcudarcu.
For the benefit of others in the community, please mark your post as the Accepted Solution.
--Sharon
