Session timeout should redirect to Single Sign On page (SSO) on initial load
AG_11031228
Hi Team ,
At the time of session time out we want that it will redirect to SSO page not on the popup which is asking for username and password .can you please guide to solve this problem ..
7 REPLIES 7
Hi @AG_11031228,
Thank you for your question!
Best regards,
Catalina
PTC Community Moderator
AG_11031228
(To:Catalina)
Hi Team this code is not working i took on example https://community.ptc.com/t5/ThingWorx-Developers/Redirection-on-session-timeout/m-p/522515
but while running getting error Authenticator threw an exception while invoking matchesAuthRequest(...), authenticatorName=SSORELOGINAuthenticatorExtension, exception=null
Any help highly appriciated
Can any one respond
You can check the exact exception stack trace in the ErrorLog. You won't see it in Composer, so check the file directly.
/ Constantine
Hi @AG_11031228 ,
It appears that a response may answer your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate a proper one as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
wcui
AG_11031228
(To:PEHOWE)
Any help highly appreciated
