is it possible in ThingWorx 8.5.x and 9 to force focus on a specific element (like a textbox) in a mashup during runtime? I've seen solutions in older posts with jQuery which are no longer working.
Is there any way to achive this in newer Thingworx versions?
Hello @DanZ,
You need to develop a custom widget where you place manually the focus to an element.
You can follow example at developer portal or at the Help Center page section Creating Customized ThingWorx Widgets
Hi @DanZ.
Can you point out the older posts that you're referring to? This will help us gain a better understanding of your requirement.
--Sharon
Certainly. The accepted solution in this case isn't working anymore: https://community.ptc.com/t5/ThingWorx-Developers/Force-focus-to-a-textbox/td-p/501391
I simply want to set focus to an element (like a textbox) after an event (i.e. ButtonClicked) is triggered.
EDIT: There are even cases where it is mentioned that jQuery isn't working anymore for this use case.
https://www.ptc.com/en/support/article/CS314721
https://www.ptc.com/en/support/article/CS304107
Is there any alternative?
Hello @DanZ,
Do you mean a customized textbox widget that have the function to force focus on itself? Or a separate widget that could set focus on any arbitrary element in the mashup?
I'm asking because I'm not sure if the second option is even possible.
