Oct 7, 2020 1:21 PM UTC
Set focus on textbox
is it possible in ThingWorx 8.5.x and 9 to force focus on a specific element (like a textbox) in a mashup during runtime? I've seen solutions in older posts with jQuery which are no longer working.
Is there any way to achive this in newer Thingworx versions?
Oct 12, 2020 8:42 AM UTC
Hello @DanZ,
You need to develop a custom widget where you place manually the focus to an element.
You can follow example at developer portal or at the Help Center page section Creating Customized ThingWorx Widgets
Support
Oct 8, 2020 2:14 PM UTC
Hi @DanZ.
Can you point out the older posts that you're referring to? This will help us gain a better understanding of your requirement.
--Sharon
DanZ15-MoonstoneAuthor
Oct 9, 2020 6:31 AM UTC
Certainly. The accepted solution in this case isn't working anymore: https://community.ptc.com/t5/ThingWorx-Developers/Force-focus-to-a-textbox/td-p/501391
I simply want to set focus to an element (like a textbox) after an event (i.e. ButtonClicked) is triggered.
EDIT: There are even cases where it is mentioned that jQuery isn't working anymore for this use case.
https://www.ptc.com/en/support/article/CS314721
https://www.ptc.com/en/support/article/CS304107
Is there any alternative?
Hello @DanZ,
