Set gadget configuration parameter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I have a gadget that has a configuration parameter "dataset" identifying the thing it should display. I can add this gadget to the dashboard, but how can I set the configuration parameter (either UI or via script), so that the gadget is properly configured on startup?
For test purposes I can embed this gadget into a static mashup and bind the configuration parameter. This works fine, but for the dashboard this needs to be dynamic and set by the user.
EDIT: I was able to call DashboardFunctions.AddDashboardItem and set the parameters argument to my desired params. I do this in a scripted call. This works for me.
Thanks. Much appreciated!
- Labels:
Mashup-Widget
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Dwight,
What datashape did you utilize for the dashboard parameters, I'm currently trying to use DashboardItemParameter. If you have a sample of your code that shows the parameter infotable setting that would be of great help.
Keri
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
nevermind, I had it right, as when I show the edit parameters, it is shows me the value I assigned, oddly in 7.3 when you display the value on the screen it isn't showing as actually set like the edit parameters is showing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Keri,
Is this different than other versions? Could you send a screenshot?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
what would you like to see a screenshot of?
