State Formatting option is not there in the Thingworx 9.0 line chart widget. In the legacy time series widget that option is there. Is there way to do state formatting in 9.0 line chart widget?
Sadagopan PSSKP
Hi @psskps , This option is not available for thingworx 9 but we have already case open for this request may be in the coming releases you would find this.
Regards
Ankur
Regards
Ankur
Hello @psskps ,
Are you able to see StateFormatting option if you bind data to the line chart widget ?
