Hello Everyone,
I had few question related to service execution and associated subsystem
1. Does anyone know if Datatable related services (like Add, Update, Delete) etc are handled through 'Stream Processing Subsystem' ? I do see a separate subsystem for valuestream but there is nothing specific to Datatable so I was wondering if the services are queued for processing (when multiple threads are trying to access the same data table) using Stream Processing Subsystem ?
2. The other question I had was with respect multithreading ! When Thing service (same or different) is called from an external system using REST api, will Thingworx spin up a new thread for each call ? Please clarify,
3. Also which subsystem handles the execution of thing services ? Are they executed innediately or queued based on active threads and other parameters?
4. Finally is there a way to monitor what threads are active in memory ? which processes are taking long time than usual etc ?
Appreciate any explanation or pointers to a guide which has this info ?
1. About DataTables -> It are processed synchronously, Database transaction goes through the execution of the initiating service call (and inner services from the same call), the stream processing and value stream processing doesn't takes part of it.
2/3. There's different pools of threads that are reused and a max thread pool size (Event Processing, WS Execution Processing,...), from TW documentation:
you have a good read on recommendations by Adam Ressler @AdamR: https://community.ptc.com/t5/IoT-Tech-Tips/Performance-Design-Pitfalls-and-Troubleshooting/m-p/535165#M347%3F
4. As pointed out by Adam in the previous post, there's tools to do thread dump : https://marketplace.ptc.com/apps/218764/thingworx-support-tools#!overview , it's also on PTC Software Download site. And also for a more in deep analytics on execution starting on TW 8.2 you have the PTC System Monitor 6.0 .
Just my two cents,
Carles.
Just my two cents,
Carles.
thanks @CarlesColl for the reply and pointers to the guide. One follow up is that in point #1, I was talking about Thingworx Data tables and not Database Tables ! Are the TWX Data table services handled synchronously ? or you are talking about Database tables ?
Either I was referring to Thingworx Data tables
Hi @raghunayak.
If the reply from @CarlesColl answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
