Suddenly I can not save a specific Thing,ThingShape,ThingTemplate
json-2
As if it were locked,It can not be saved. How should I find the problem
And I can not open a Thing corresponding to a ThingTemplate
10 REPLIES 10
supandey
(To:json-2)
Hi Junghun, have you checked the log files from ThingWorxStorage/logs location? Is this only happening with one type of ThingTemplate? Which persistence provider are you using with ThingWorx?
posipova
20-Turquoise
(To:json-2)
This seems like your license is not loaded properly. When you go to ThingworxPlatform folder, what files do you see there?
json-2
(To:json-2)
keywtore-password  , license, platform-settings.json Fils can see.   What should I check or how
json-2
(To:json-2)
Is there a limit on the number of Thing for each ThingTemplate?
In a specific Thingtemplate  There are a lot of thing. The only special task is to change the properties of a specific ThingTemplate in a specific Thing. That's it
It is in the current state
json-2
(To:json-2)
It seems to me that everything related to Thingtemplate is locked.
json-2
(To:json-2)
Fixed ThingShape and it's been stopped
Any Thing that inherits the ThingShape will get the following error. I can not find what the error is
supandey
(To:json-2)
As far as I know the entity creation limit is applied in general not particularly to specific to ThingTemplates. You can check your license usage by navigating to the ThingWorx Composer > Monitoring > Subsystems > License Subsystems Settings
These should be able to highlight if you have used all available quota of Things creation.
Additionally, I would still encourage you to please have a look at the application log to get more specific error info.
json-2
(To:json-2)
There are no other restrictions except for "twx_named_user"
json-2
(To:json-2)
Another Question.  We're running a 10-second scheduling, but can not you fix the ThingShape for the service that's running when scheduling is running? Once fixed, all the Thing turned "is not running" for a while.
supandey
(To:json-2)
Sorry i am not very clear with this question. Could you please elaborate or illustrate with some examples/screenshots?
Concerning the saving issue, wondering if you have tried restarting the ThingWorx server?
