I was hoping to install the latest version of PTC Analytics Server 8.2 on Windows 2016. Is it still a requirement to have Postgres installed and set up for Analytics Server? Our team was hoping to have everything Windows based, so we are planning to use Microsoft SQL Server for Thingworx Core installation. I don't see Postgres on the requirements document on 8.2 for Analytics, but I don't see any RDBMS requirement on there either.
Thank you,
York Prado
Hi
As you have correctly noticed there is no RDBMS requirement in ThingWorx Analytics 8.2.
ThingWorx Analytics 8.2 does no longer use any database. Data are saved on the file system as parquet format.
We also have a native Windows installer with 8.2 (in addition to the docker one) , so you should have a more familiar Windows experience with this new release.
Hope this helps
Kind regards
Christophe
Hi
Hope this helps
Kind regards
Christophe
York,
Thank you for posting to the Community.
As of ThingWorx Analytics 8.1+, we no longer require a DB for use of our application.
There were changes to the architecture, and currently the data is stored in Apache Parquet format on the File System, which is handled by the Analytics Application directly (no need for an installation steps).
You can use any flavor of ThingWorx Foundation for your front end, but it is required that you have a running ThingWorx Foundation Server prior to installing ThingWorx Analytics.
I have attached the Installation Guide for TWA 8.2 - Windows Deployment for your reference. Please let me know if you have any additional questions.
Neel
Hi @yoprado
I just wanted to follow up to see if Christophe and Neel's responses answered the questions you had. If so, please indicate the appropriate response as the Accepted Solution for the benefit of reference for our Community. If you have further questions/issues, please advise on your current status.
Thanks!
Leigh
