Tab Widget - CSS for Tab selected
Arun_C
Hi Team,
Following on the Tab CSS - Blog Link. I also needed to change the ptcs-tab selected header color and styling  based on the customer UI requirement. I used the below given CSS, Its working properly in TWX 8.5.
But in TWX 9.4.0 its not working as expected.
.TabsArrow .widget-ptcstabset::part(tabs-tab)[selected]
    background:  #0094C8 !important;
    border-bottom-color: #EEEEEE !important;
.TabsArrow .widget-ptcstabset::part(tabs-tab)[selected]:before
    content: '';
    width: 0;
    height: 0;
    border-top: 17px solid transparent;
    border-bottom: 17px solid transparent;
    border-left: 15px solid #EEEEEE;
    position: absolute;
    display: block;
    top: 0;
    left: 0;
 .TabsArrow .widget-ptcstabset::part(tabs-tab)[selected]:after
 {  content: '';
     width: 0;
     height: 0;
     border-top: 17px solid #EEEEEE;
     border-bottom: 17px solid #EEEEEE;
     border-left: 15px solid #0094C8;
     position: absolute;
     display: block;
     top: 0;
     right:0;
Kindly provide some workaround for this case to fix in TWX 9.4 Versions.
Thanks & Regards,
Arun C
Velkumar
(To:Arun_C)
Hi @Arun_C
CSS Syntax got changed from TWX 9.3.4
Please follow the new syntax -
Related Article
https://www.ptc.com/en/support/article/cs377455
Tabset CSS on Tab Selected - PTC Community
/VR
Velkumar
(To:Arun_C)
Hi @Arun_C
Related Article
/VR
Thank You @Velkumar . After updating with syntax , now its working properly.
@supports (ptcs-style-unit: "PTCS-TAB-SET") {
  [part=tabs-tab][selected] {
     <<CSS>>
    [part=tabs-tab][selected]:before {
     <<CSS>>
    [part=tabs-tab][selected]:after {
      <<CSS>>
