Terminate/End SSO user session on Logout
TanmeyTWX
Hi Experts,
Please suggest a way to terminate user session from browser once the Logout is triggered.
The user is being authenticated through SSO and want the user to click a button(probably logout) and should be redirected to login again to enter the Azure AD credentials instead of re-login automatically because the session is still alive.
I have already tried TerminateUserSession resource but that works only for Administrators group members and I have non-administrator custom user groups with specific permissions.
Note: Don't want to redirect to a different mashup/screen as a workaround.
TIA.
You somehow need to trigger the logout in your IdP as well. There is an older PTC article stating you need to call the "Singe logout url" of your Idp: How to logout from ThingWorx after signing in with SSO
I did not yet try to configure SingleLogout. If you find out more I would be happy if you can share details.
PaiChung
22-Sapphire I
(To:TanmeyTWX)
TerminateUserSession would accomplish the same thing as the regular Logout.
Your challenge is the fact that Azure AD is not receiving a termination and is holding the session for xx minutes still.
Strange though, because even when using AD that shouldn't be the case, might be a side effect of how your SSO setup works?
I can understand it, if your logout isn't an actual Thingworx logout or if users just close the browser.
What 'Logout' are you using?
Pai,
I have configured SSO as mentioned in this PTC guide. SSO with Thingworx.
I have used Logout Function ,part of Mashup functions not widget.
TanmeyTWX
(To:nmutter)
Hi, Tried Single logout url also but it doesn't end the session in a way. Reloading or hitting browser back button is getting the user logged-in again
I have tried with .srf single logout url and seems to be working. Thanks!
