I have mashups specific for mobile screens. Whenever open those mashups if it has a textfield it is automatically opening the keypad. How to check which triggers this. Is there a way to fix it. The focus should happen only on touching the field
Hello @KT_10107318,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
