We have a scenario where we need trigger event after when new file uploaded to our file repository. What's the best way to implement it?
If you use the upload widget or the filetransfer copy function, there will be a completed event you can use.
if you don't have those, then you'll have to do some sort off 'file watcher setup' where a timer or scheduler check the folder
OR if the system that is sending the file has the capability, it could invoke a rest api call
thanks a lot for your reply!
