The best way for trigger event?
and1
We have a scenario where we need trigger event after when new file uploaded to our file repository. What's the best way to implement it?
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:and1)
If you use the upload widget or the filetransfer copy function, there will be a completed event you can use.
if you don't have those, then you'll have to do some sort off 'file watcher setup' where a timer or scheduler check the folder
OR if the system that is sending the file has the capability, it could invoke a rest api call
PaiChung
22-Sapphire I
(To:and1)
and1
(To:PaiChung)
thanks a lot for your reply!
