Thing is not enabled even though EnableThing/RestartThing is called
cmelancon
7-Bedrock
I am trying to create a DataTable from a service.
try {
    var thingParams = {
        description: undefined /* STRING */,
        thingTemplateName: "DataTable" /* THINGTEMPLATENAME */,
        tags: undefined /* TAGS */
    // no return
    Resources["EntityServices"].CreateThing(thingParams);
    Things["MyDataTable"].EnableThing();
    Things["MyDataTable"].RestartThing();
    Things["MyDataTable"].SetProjectName({ projectName: "MyProject" });
    Things["MyDataTable"].SetDataShape({ name: "MyDataShape" });
} catch (err) {
    logger.error(me.name + " Service DataTableHelper.WriteToDataTable has an error on line #" + err.lineNumber + ": " + err.message);
I get the foolowing error:
DemoFileHelper Service DataTableHelper.WriteToDataTable has an error on line #14: com.thingworx.common.exceptions.InvalidRequestException: Thing [MyDataTable] is not enabled
Line 14 is the one where I set the Project Name.
Any help would be welcomed.
I have moved the setDataShape declaration a bit higher and it seemed to work. (changed the datashape and project name with something on my system).
try {
    var thingParams = {
    // no return
	name: "ad" /* DATASHAPENAME */
    Things["MyDataTable"].SetProjectName({ projectName: "GitBackup" });
} catch (err) {
try {
    var thingParams = {
    // no return
} catch (err) {
Thank you, it worked!
