I try to connect a Microsoft SQL Database to ThingWorx … I installed the JDBC MSSQL Connector Extension from the Marketplace and imported it … Then I created a Thing “DB1” with the Base Thing Template MSSqlServer… In the Configuration page I tried to configured…
JDBC Driver Class Name:
com.microsoft.sqlserver.jdbc.SQLServerDriver
JDBC Connection String:
jdbc:sqlserver://127.0.0.1\SQLEXPRESS;databaseName=thingworx
connectionValidationString:
SELECT GETDATE()
Database User Name:
sa
Database Password:
my password
after saving I get the Message Thing[DB1] is not running…
can anybody help me?
I use..
Thingworx:8 trial
Microsoft SQL Server 2017
best regards!
I'm suspecting the extension might have not been updated in a while and the driver supplied is old.
Could you please take a look at my response to this thread (first comment) for detailed instructions on how to package a new jdbc driver?
It seems the db connection is not getting established. Do you have all the needed ports enabled in your SQL database? Check ThingWorx application log for errors.
In the ThingWorx application log is the following message:
ERROR starting: JDBC Driver Class Not Found: com.microsoft.sqlserver.jdbc.SQLServerDriver
Error message: Thing is not running
in my SQL Management Studio my instance port 1433 is enabled.
- the Windows Firewall is off.
- FYI my Windows Server 2017 is a VM Ware.
Do you have TCP/IP enabled in your SQL configuration manager?
Yes- my TCP/IP is enabled.
do I need to install a JDBC driver on my Windows Server?...or is importing the JDBC package from the ThingWorx Marketplace sufficient?
Is it possible that I need to change the JDBC metadata file?
thank you for your help! :-)
