Thing is not running - SQL JDBC
GrafZahl
6-Contributor
I try to connect a Microsoft SQL Database to ThingWorx … I installed the JDBC MSSQL Connector Extension from the Marketplace and imported it … Then I created a Thing “DB1” with the Base Thing Template MSSqlServer… In the Configuration page I tried to configured…
JDBC Driver Class Name:
com.microsoft.sqlserver.jdbc.SQLServerDriver
JDBC Connection String:
jdbc:sqlserver://127.0.0.1\SQLEXPRESS;databaseName=thingworx
connectionValidationString:
SELECT GETDATE()
Database User Name:
sa
Database Password:
my password
after saving I get the Message Thing[DB1] is not running…
can anybody help me?
I use..
Thingworx:8 trial
Microsoft SQL Server 2017
best regards!
posipova
20-Turquoise
(To:GrafZahl)
I'm suspecting the extension might have not been updated in a while and the driver supplied is old.
Could you please  take a look at my response to this thread (first comment) for detailed instructions on how to package a new jdbc driver?
https://community.ptc.com/t5/ThingWorx-Developers/Using-a-third-party-Jar-file-for-Database-connection/m-p/514861
6 REPLIES 6
posipova
20-Turquoise
(To:GrafZahl)
It seems the db connection is not getting established. Do you have all the needed ports enabled in your SQL database? Check ThingWorx application log for errors.
GrafZahl
6-Contributor
(To:posipova)
In the ThingWorx  application log is the following message:
ERROR starting: JDBC Driver Class Not Found: com.microsoft.sqlserver.jdbc.SQLServerDriver
Error message: Thing is not running
in my SQL Management Studio my instance port 1433 is enabled.
- the Windows Firewall is off.
- FYI my Windows Server 2017 is a VM Ware.
posipova
20-Turquoise
(To:GrafZahl)
Do you have TCP/IP enabled in your SQL configuration manager?
GrafZahl
6-Contributor
(To:posipova)
Yes- my TCP/IP is enabled.
do I need to install a JDBC driver on my Windows Server?...or is importing the JDBC package from the ThingWorx Marketplace sufficient?
Is it possible that I need to change the JDBC metadata file?
thank you for your help! :-)
posipova
20-Turquoise
(To:GrafZahl)
slangley
(To:GrafZahl)
Hi @GrafZahl,
Please review this post for possible solutions.  If you're still having issues, please provide more information regarding your configuration.
--Sharon
