Good day,
I have noticed an issue in new composer with regards to data change subscriptions on a thing shape. It seems that when I create a data change subscription on the thing shape, I am unable to select any of the properties that I have created on the data shape as the required property that triggers the subscription. Below is an image of my created properties followed by an image of the subscription setup.
I have made sure to save the properties before trying to create the subscription.
I am able to create data change subscriptions on properties that I have created on the thing shape in the classic composer. Please see images below.
The example above was done in ThingWorx version 8.3.2 but I have also found the same issue in version 8.0
Has anyone experienced something similar?
I do see this happening. I also noticed if I start creating a subscription but then cancel without actually creating it, i get an error "property is required". Could you please confirm you are seeing this too?
EDIT: both issues appear to be fixed in 8.3.3, per defect/jira TW-42100.
I will try to reproduce this on mmy local set up and update you with the results.
Hi @eengelbrecht.
If the response provided by @posipova helped to solve your problem, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
