ThingWorx 5 Import
sbeckers
ThingWorx 5 Import
Glad to hear about the release of ThingWorx 5! I have installed it on my PC, but now I'm having an issue with the import of entities from a ThingWorx 4.2.0.15 installation. When I try to import entities, I get the error:
<br>
Unable to process import: Validation Failure: ThingTemplate InstrumentTemplate Had An Invalid Parent Thing Template :
<br>
In the logs, I see that the error is triggered by:
Cannot Create System Objects : Ignoring Imported Object ThingTemplate
<br>
So it appears that 'Edge' is a System-Object ThingTemplate in 4.2, and System Objects aren't imported. But there is no ThingTemplate called 'Edge' in TW 5, is that possible? Is there a way to fix this?
Stefan
I uploaded the application log, at /ApplicationLog - Copy.log
paic
(To:sbeckers)
It looks like you need to first install the Always On extension which comprises of the old XMPP Edge Microserver functionality.
sbeckers
(To:paic)
Thanks, I installed it. Now I get the error:
Unable to process import: An Invalid Event was referenced in a subscription in ThingTemplate ConsoleTemplate
ConsoleTemplate's BaseThingTemplate is EdgeEnhanced. I've checked and the EdgeEnhanced ThingTemplate on the TW 5 server has the FileTransferAudit event defined, so I don't know where that error comes from.
adam11
(To:sbeckers)
Hi Stefan,
I was able to reproduce this issue and I've logged it to our issue tracker. I'll keep you posted with updates on a fix or possible workaround.
Adam
Ok, thanks!
