Hello all,
I meet a strange behavior.
I am a ThingWorx developper and I keep different instances of thingworx on my laptop.
I have multiple folders with ThingWorx's Tomcat and storage inside.
In everyone of these folders, I have a setEnv.bat under Tomcat/bin which indicates the location of platform-settings.json using
set THINGWORX_PLATFORM_SETTINGS=G:\GIVEN_SPECIFIC_PATH\Storage
And it totally works when I have ThingWorx 6.x wars deployed.
BUT
When I replace ThingWorx.war by a ThingWorx 7.0 war, it doesn't work anymore and plugs to the storage at the root of the drive.
I see that because, i see that I have different things or data depending on the war I use.
And when I go back to a ThingWorx 6.x war it works again.
How can I make sure that ThingWorx 7 takes into account the right platform-settings.json?
Thanks in advance.
As a work around try putting the platform-settings.json file in the root/ThingworxPlatform folder
Creating C:\ThingworxPlatform\platform-settings.json, in place of setting the location in THINGWORX_PLATFORM_SETTINGS in setenv.bat, didn't seem to do anything for me in TW7.1. (Tomcat is running from the C: drive so it still creates C:\ThingworxStorage, etc.) Is that what you meant? Should it be working?
For the record, the format of platform-settings.json has changed completely. The details are in the 7.1 install guide, available at support.ptc.com -> Thingworx Platform -> Reference Documents.
Defining THINGWORX_PLATFORM_SETTINGS environment variable doesn't work in ThingWorx7.0. But the workaround specified by Pai Chung should work.
I had to change the storage location on a windows installation recently (ThingWorx 7.2).
Here is the quick "how-to" for doing it.
1) Stop Tomcat
2) Copy existing "ThingworxBackupStorage" and "ThingworxStorage" folders to the desired location. "C:\PTC" is used in this how-to..
3) Set the environment variable THINGWORX_PLATFORM_SETTINGS to C:\PTC
4) Put the code from below to the C:\PTC\platform-settings.json
5) Start Tomcat
"PlatformSettingsConfig": {
"BasicSettings": {
"BackupStorage": "C:\\PTC\\ThingworxBackupStorage",
"Storage": "C:\\PTC\\ThingworxStorage"
