The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello everybody,
i worked through this ThingWorx Analytics Quickstart. Now i want to try this on a local TWX plattform (6.6).
Is there any possibility to get a standalone version of this Analytics Server (as costumer or in Academic Programm)?
Or could we get access to an existing server?
And if we have access how do we configure/get the neuron-application-id and neuron-application-key, which we need to connect to our TWX plattform?
Thanks for all comments and your help
Timo
Hi Timo
If you want to use your local ThingWorx platform you can start out with ThingWorx Machine Learning extension, this can be found in the marketplace. http://marketplace.thingworx.com/search?q=thingworx
You can also use a local virtual machine, to run ThingWorx Analytics, this would require a request to PTC would you like me to move further with this?
Best
Asia
Hi Asia,
i already got this extension. After importing it into our local TWX plattform i was able to create a Thing based on allNeuron. So in its configuration i can set up a connection to a endpointHost, which i think is a ThingWorx Analytics Server's IP.
So where to get access to such a server and where to get my Id and Key?
The second solution running on a local server (or virtual machien) might also be interesting...
Timo
Hi Timo
You can create your own server with a 30 day free trial. Please follow the link.
http://developer.thingworx.com/dashboard
Best
Asia
Thanks.
But i already did this...
If i want to use it on my lacal version, is it possible?
Is it possible to get not just a trial version?
This server seams to be preconfigured... so noramlly you have to configure it like creating neuron-application-id and neuron-application-key, right?
Best regards
Timo
Timo,
We plan to make a version available for local download, but this is not yet available. For now, you can evaluate the ThingWorx Analytics Server using the cloud-based version.
Dave
Dave,
Tanks. These are good news.
So is there any possibility to extend this 30 days demo version and also (instead of using my own Password as ID and having no application key) to create a personalized id and key?
Best regards
Timo
Hi Timo,
At the moment extending the 30 days is not possible.
Kind regards,
Asia
